davidmichael
Active member
haha I remember that one
:slapI have done a basic 2 day training in domestic electrics
well at risk of stating the obviously, like others have already done, i would use an RCD tester. do you see how that works? and what did you use to test continuity? nothing? or what about IR? or was that ignored too?Why not be a little more constructive and tell me how you would have tested it. There was no one anywhere near the wiring.
i wouldnt trust him to do either of those safely2) leave your extent of lectrics to change a plug or lamp?
Andy Andy Andy I do appreciate where you are coming from believe me. You don't learn a thing in two days just a bit of common sense and even that didn't work! I don't need to do all those tests as the Sparky is coming on Monday.
Thanks everyone for your help and time.
With ameteurs like this doing our work no wonder there is so much sub standard installation work on refurbs these days.Andy Andy Andy I do appreciate where you are coming from believe me. You don't learn a thing in two days just a bit of common sense and even that didn't work! I don't need to do all those tests as the Sparky is coming on Monday.
Who is to blame? Well in this situation the agreement between the builder and the spark that allows the builder to do work of a sparky. Simples.But the question is who is to blame?
Him for having a go at something with limited knowledge, I'm sure we've all been there and done that at some point or...
The alleged bodies for permitting the watering down of the trade? Water anything down and irrespective of how dangerous it may be or have been it will soon be perceived as easy and nothing to worry about???
Similarly it could be said that the constant changes with the regs and the big reliance upon RCDs is out of touch with reality in the sense that there are probably more installs without and rcd.
Agreed Sharpend thanks for your feedback. I did not power it up but the guy I am employing said he was experienced and now I know that that was not the case. I agree to this point. only run cables leave connecting up to sparkySo if the sparky is coming to test and sign it off why did you power it up in the first place? Surely to confirm an rcd you would look at the CU and circuit designation within the cu?
If I could offer some advice it would be either;
1) only run cables leave connecting up to sparky
Sorry if that sounds harsh but you must realise that this is an open forum and whilst you may have been lucky the next person may not.
Andy as you have 11k posts behind you I have not option but to respect everything you say.i wouldnt trust him to do either of those safely
clearly you dont understand, or you would know your limits and not do something so stupid
and if you read the thread instead of spamming the place, you would have noticed he has already bodged the job, so a bit late now...Andy - Can the work not be signed off under the 'Third Party Certification scheme' as mentioned in Approved Doc P of the building regs? Obviously the OP would have had to engage the Third party prior to commencing the work in order to do this.
No, this work is not notifiable.Andy - Can the work not be signed off under the 'Third Party Certification scheme' as mentioned in Approved Doc P of the building regs? Obviously the OP would have had to engage the Third party prior to commencing the work in order to do this.
