Hi All,
Just done a small job as follows:
Theres and existing 2.5mm feed to the garage spured from the back of a socket in the house. (Not a very long run volt drop, R1+R2 fine).
I've installed an RCD FCU 13A in the garage to supply a dso with a fcu in line to the 1.5 for the light.
My question is to certificate my work do i need one or two MWC's as there is 2 fcu's with different cable sizes and fuses?
Many Thanks
Many Thanks
