just ordered my set of wagos free from the website
I ordered the free Wago Sample that someone put on here Last Year?And the one dado? used on walls in offices etc.
I don't know if it was because I was in a rush and bought them off of am eBay seller - but the Lever wagos that I bought had very dodgey levers (I couldn't open them - Just a fraction).
Now deke could be on to a real good earner here he could breed Brians every sparks will have one bit like bladerunner you either love them or hate them.:O:O:|
oh dear.......... couldn't open the levers:yellow card
you need to have your three Shredded Wheats!
OR
Ask Admin2 to open them for you!!!!!!!!!!!!!!!!!!!!!!
they are meant to be stiff action.....
so that when you lock them back down on the cable to don't easily pop-open again!!! headbang
Wet Fish
:C :C:C:C
even Brian can do them!
:Blushing :xGuinness
Have you been viewing the NAPIT forum somehow batty?bit like bladerunner you either love them or hate them. :^O
I have a lonely life member of every forum.Have you been viewing the NAPIT forum somehow batty?
The 'workshop' shed had a consumer unit with a main switch, a 16A radial and a 6A lighting protected by a 20A in the house consumer unit. That is split load 2 X 30mA RCD's (16th edtn)luuuuuuuuurvely patchwhat are the protective device arrangements?
pics
test sheets ?
TBH my thoughts were the chances of damage occurring to the T&E on the roof very minimal. T&E a bugger to pull through the conduit and I was reluctant to buy rolls of 1.5mm in addition to the 2.5mm. So really it's a cost vs benefit compromise.I was guessing floor board.Nice job patch. How come you didn't take the conduit to the light?
I have used most of three 3 meter lengths! Still will use it up when I swap the wiring over in my workshop - when I get the time.Any way after carefully studying your pics.....
from your 90m of conduit..
I calculate you have about 88.5m leftover?!
:^OROTFWLROTFWLROTFWL
:C
T&E + Conduit = Not goodTBH my thoughts were the chances of damage occurring to the T&E on the roof very minimal. T&E a bugger to pull through the conduit and I was reluctant to buy rolls of 1.5mm in addition to the 2.5mm. So really it's a cost vs benefit compromise.
I have some silicone spray that I use on the bed of my little planer thicknesser!T&E + Conduit = Not goodThat combination can indeed be a bit of a sod.. Best Avoided....
need to keep the T&E flat.. stop it twisting...
But that said do occasional do it on shortish runs along external walls to outside lights
bit of silicone spray can ease the insertion!
http://www.screwfix.com/prods/13662/Plumbing/Plumbing-Accessories/Silicone-Spray-400ml?cm_re=SEARCHPROMO-_-SILICONE%20SPRAY-_-13662
Always keep a bit of this anyway for occasion push fit pluming connections..
ut the kettle on
:^O :^OAdmin clearly is weak!![]()
Did you get your free sample Wagobox? Was it wired up? Mine came with a 2 way push a 4 way push and a 2 way lever as an example of how to connect it up.:coat I pulled it right back and the lever was bending.
:yellow card
:ApplaudThe 'workshop' shed had a consumer unit with a main switch, a 16A radial and a 6A lighting protected by a 20A in the house consumer unit. That is split load 2 X 30mA RCD's (16th edtn)I tested for continuity of all the conductors using some of the singles as a wander lead and all end points. All socket outlets also test OK with my plug in socket tester. I also tested the rcd.
I appreciate not perfect in terms of testing, but more than the average DIYer would do [i have verified continuity of cpc at all points]
:yellow card
I could have for the switches and the fluorescent light but the two lights on the shed wouldn't have taken 2.5mm single!No they are stiff. Why not use the singles you have for the lighting, Patch?
HHHMMM Mr SL i would say the 2 way is a non Wago![]()
:|What were you using?
your pliers?
They should just click up like this....
form another angle...
You can see the little metal inside bits that come down when the lever is 'closed'.
And they all close up again...
Can you spot the one that isn't a Wago???? ; \![]()
:x
I have never had any that don't open and close correctly?
