Power Rating 220 - 240v/50 Hz3.8kw x 4 = 67ampsNo diversity is allowed will the supply you have be able to take the extra load?
OK wasnt sure it was OK to do this or not, thought it might be an option though!You could fit a 40A MCB and feed a 4way Bd with 4 10A MCBs in it .
Is this in principal no different from a small garage/shed CU fed from a dedicated MCB in a house?Yes Vlad, theres no problem with doing it that way. The usual trick when the old Wylex 6 ways were full up and you wanted to add a new circuit was to remove the two lighting circuits, put them in a 2 way C/U fed from a 20A MCB. You then had a spare way in the 6 way for whatever.
Yep !Is this in principal no different from a small garage/shed CU fed from a dedicated MCB in a house?Doc H.
Is nuisance tripping a likely issue? Can i assume from your name you have a fair bit of experience with these type of things then?But if you install them on one ring or radial you have put 4 heaters on one cctand yes they are treated as heaters.
I would put the wiring off RCD because of nuisance tripping on compressor start up.
If the A/C unit is rated at say 4A we always install 2.5 on 16A radial because if the A/C unit is turned off then back on again the comp will be under load and likely trip anything smaller
Had it once or twice in the begining that is why i am now carefull and always try to overcompensateIs nuisance tripping a likely issue? Can i assume from your name you have a fair bit of experience with these type of things then?
You could fit a 40A MCB and feed a 4way Bd with 4 10A MCBs in it .Or Henley blocks and split the tails to a 6 way.
just take all the glory :coat ROTFWLOK wasnt sure it was OK to do this or not, thought it might be an option though!
