Sharpend
"It Just Is"
Hager switches now have a neutral terminal built in, most convenient.
not really, you are not going to have ten lights run off one back box!So is this a spider method but done through switches rather than JB's? Personally when rewiring and even new stuff I generally loop into switches unless its pendants. Then I may three plate but I also may loop in switches. It just depends on the day. I have also used the spider method at switches many times.
Good job.Hager switches now have a neutral terminal built in, most convenient.
Was it a low energy lamp fitting, or LED, by any chance...?Good job.
I once found someone who was very "inventive"
Live feed into L1
Switched live out from Com to light
L2 used as a neutral terminal :shakehead
Would sure confuse most people that saw it. I'm NOT recommending that as a way to do it.
no it was a normal lamp in this case, but that might be a good solution to try if you do get a problem LED lamp.Was it a low energy lamp fitting, or LED, by any chance...?
i.e. Do you think that it may have been done deliberately to stop that annoying light flicker while the switch is off....
Basically putting a neutral across both sides of the lamp whilst off..
:C
In the words of the great Professor Heinz Wolfe [great egg race, original version]....."that is a very elegant solution to a very tricky problem"Was it a low energy lamp fitting, or LED, by any chance...?
:C
Now that was a quality show!In the words of the great Professor Heinz Wolfe [great egg race, original version]....."that is a very elegant solution to a very tricky problem"
Secret Life of Machines was another good show...most of it is on You TubeNow that was a quality show!
