Great post, thx PC. One thing, with the adapter box, these can be butted up against the CU? and do i need to put a grommet inbetween maybe? I suppose if the box is flush with the CU then there will be no ingress i.e. IP4x which will normally required for the top of a CU.
Upon checking the OSG, found that the minimum height for a catenary wire supported cable is 3.5m. My garage is only 2.8m high and the flat roof extension on the other side is only 3m high. Looks like i will have to take up my decking and run the SWA under this. The decking butts up against the garage so should be fine. In fact in retrospect this will probably be a better bet. As to drilling holes in the joists of the decking, do the same regs apply as to a building i.e. 50mm from the top or the bottom?
Another question.. As this is notifiable work, will i need to notify the council before i start the work even though this is an assessment installation for Part P?
Thx, Richard
Thx, Richard
