Could you post a photo of the new fitting?
It's the ones I posted earlier. See attached.Could you post a photo of the new fitting?
For clarity one side is the supply end, the other is the light fitting itself. They're designed to be screwed in separately and then the black connectors fit together with ease so you don't have to screw them in whilst holding the light up high...It's the ones I posted earlier. See attached.
We mean the actual light fitting that is on the other end of that white flex coming out of the black connector, to see exactly what the light fitting is made of and see if there is an obvious fault with it.
