Yes the origin is now the FCU.You think the circuits start at the CU and there is nothing before that? Following that quasi-logic(sic) then the CU should never be installed as its part of a circuit that starts at a transformer.
314. That is why we are fitting the FCU/other device to separate the circuits.
As for Apdx 15. That I believe is a copy and paste error as radials do not start AND finish at a CU.
I am not getting drawn into another debate with you over this as you seem to be arguing with every answer that is not the same as yours and to the extent you are doing it is unhelpful and destructive. The OP seems happy with these suggestions so I am unsure why you are persevering with this crusade apart from to give you something to do.
It's not that I think the circuits start at the CU, it's what is described in Appendix 15 of BS7671.
How does feeding a circuit from another circuit comply with 314? I thought that one of the requirements of 314 was to minimize inconvenience in the event of a fault?
There was me thinking that it was a requirement to provide both overload and fault protection where there is a reduction in the current-carrying capacity of a conductor.
Does this mean that every fused spur off of a ring is a separate circuit?
How do you record the test results when issuing a certificate, or conducting a PIR?
Yes if you have an old copy of BS7671, and have not obtained the corrigenda then you will have those errors in Appendix 15, there are also a number of other errors that the corrigenda addresses.
I feel it is advisable to keep up to date with the regulations.
Is it my magnetic personality that draws you into these debates, or do you enter them of your own volition?
I will remind you, that it is you that has disagreed with me, so if any one is argumentative.......
The OP may well be happy with suggestions, I wonder if he will be happy to sign a document stating that his work complies with the Regulations, when in fact his work doesn't.
Producing a false instrument is considered quite a serious offence, and I doubt that a defence of some people told me on a forum will cut any ice.
