TBH I'm not bothered if I get the remedial works ............. all depends on the client and their attitude towards an "unsatisfactory" report ....................
PAT testing is outside the scope of an EICR
Where in BS7671 does it say all sockets need to be switched ?????????????????
Totally in agreement here, I never cease to be amazed by people who ask for an EICR, then seem surprised when it is unsatisfactory, quite often the installation has received no proper maintenance over the years, or has been messed about with by the diy brigade. Would, one wonders, these same people be as surprised if having not maintained their car for a year, it failed the annual mot, probably not.
I had one landlord, he was quite happy to let his tenants do whatever they wanted in one of his properties, following the EICR, which I had issued and was unsatisfactory, he asked what it would cost to get a 'clean' report. I told him there was about £300 worth of work needed to sort it, fundamentally, the installation was fine, the problems were down to the idiot tenant and his alterations. he'd 'installed' about a dozen outside lights in a tiny garden, some were connected straight out of the back of a socket (pir fittings), ones requiring switches were wired the same, but with a switch inserted, no fusing down whatsoever. He needed to add one light and decided to connect it to the boiler feed, the trouble was he couldn't get his feeds into the box as there were 3 cables in already(2 ring and one boiler feed), no problem, fit another surface box and drag the 'spare' cable (one leg of ring) out of the boiler feed, so now he's got 2 radials instead of a ring circuit. The annoying thing about this was that about 3 years previously I had rewired the house and knew it was right, now he needs a cert because of a change of tenant and all this comes to light, and the landlords attitude was, "well how come there's all these problems when you only rewired it 3 years ago", like it's my fault.
