once youve done work on a few TT places, youll soon find out its not much harder than TN supplies
I love em I would change them all if I had my way.once youve done work on a few TT places, youll soon find out its not much harder than TN supplies
1. Its not unusual to find an old earth rod has been buried under a tarmac or block paving driveway....Not done any tests but I inspected the 2 fuse box's and there is no main earthing at all. All the cpc's from each circuit coming into the fuse box just connect to the external metal fuse box unit, there is no earth bars or anything. I have not long been in this game and this is my first tt system I have seen due to me working in a busy built up area. I have walked around the outside of the property with the owner and there is no sign at all of the rod location. Is it a common situation to find there is no earth rod's in tt systems?
What do you mean by the external metal fuse box unit? Are you implying that the CPCs end up connecting to the cast-iron cut-out? It may be the case that you have a TN-S supply at the cut-out.All the cpc's from each circuit coming into the fuse box just connect to the external metal fuse box unit, there is no earth bars or anything.
surely if you install a rod indoors you are penetrating the damp proof course which will cause no end of problems.every rod ive installed indoors has always had a decent reading (less than 100). but its often only a few metres to 'outside'
In a modern house you would,,, but Visqueen wasn't about in Victorian days and they relied on the DPC in the wallssurely if you install a rod indoors you are penetrating the damp proof course which will cause no end of problems.
