- Jun 21, 2008
- 17,023
- 47
Have you got a fleece?
My reasoning behind jus changing the stat was because it's never been replaced since I've had it, so it's 7 years old!Noz,You can easily check the thermostat function in the van.
If the water pump IS u/s & cam belt driven then yes change the belt & tensioner idler etc. at the same time.
Are you sure there is enough water in the rad?...
If it is down you need to find where it is going first, could be that the rad cap is weak also.
provided the pump is not driven by the cam belt, just buy a gasket so you can remove it to check its condition. Don't buy a pump straight off in case you don't actually need one.I think in order of cost I'll....Make sure inlet is clear of leaves etc
Try and clear any possible air locks
Flush the cooling system
Change the thermostat
Replace the pump (and cam belt and pulleys while they're there)
Oh and not forgetting to put some fresh anti freeze in once I've got it working!
