No. of Turns (Transformers)
Bane
Oct 17, 2008
215
Hi people,
I apologise if this question has come up before. I've obviously overlooked it whilst perusing the library.
Is there a formulae for working out Number of Turns (Primary and Secondary) with only the following available data:
Input (VA)
Output (VA)
Primary Current
Secondary Current
Primary Voltage
Secondary Voltage
Resistance
Efficiency
I've come to the conclusion that there isn't but I shall trust myself to your better judgement.
Thanks Andy but transposing that formula still entails me needing at least one value of turns on either primary or secondary.
Ns= Us x Np/Up
Np= Up x Ns/Us
Because the number of turns primary & secondary are proportional with each other, you have to have one of them to know what the other is going to be.
simple example:
consider a shaver socket isolating transformer.. 1:1 no step up or down!
Vp = Vs e.g. 230v
Ip = Is say <1amp
Np = Ns pick a number?
if you have 200 turns primary you must have 200 turns secondary
if you have 400 turns primary you must have 400 turns secondary
if you have 127 turns primary you must have 127 turns secondary
if you have 50,000 turns primary you must have 50,000 turns secondary
if you have 73 turns primary you must have 73 turns secondary
The actual quantity will be more in relation to the gauge of the wire used to manufacture the transformer, its resistance, and how big the whole assemble has to be to it into the manufactures housing.
In a step up or step down arrangement the proportional relationship still has to apply so the transformer manufacture would have to decide upon one to them to select the correct number for the other winding.
hope that helps..Guiness DrinkGuiness DrinkGuiness Drink
So the short answer is no.
That's what I thought.
Thanks to you both for taking the time out to help.
So the short answer is no. That's what I thought.
erm.. Yes I would agree the short answer is NO!BlushingBlushing
but I dooooooo like a long answer!:^OGuiness Drink
:coat
Don't get me wrong!
I appreciate you taking the time to reply!
