now if it was upto me, you'd fail an assessment for that 'safe isolation' method. how do you know the switch turn off isolates that equipment you have dead?
it may already be turned off in DB1, but you isolate something in DB2. you start work. bloke who's machine is now dead looks at DB2, see's its isolated and assumes that its what your working on. goes to DB1 and switches on.
now you have done everything to your safe isolation procedue, but youve have left it where someone can energise the circuit without removing any locks...
had a similar thing at college.... their answer to this: it will never happen
safe isolation should be
A:check equiment is live
B: find circuit in board, isolate & lock
C: check equipment is dead
D: use known source to check voltage tester
maybe a re-energise & check, then isolate again between C & D
note: this method is not always possible, i.e if there is a wiring fault meaning its already off and unsafe to energise
