We had one setup with 3D HD Camera and goggles, it worked really well for arm work but some pilots suffered vertigo and when fish swam towards us you were ducking out of the way.
On top of the wellhead is a blow out preventer. Theres a danger that a well can kick with high pressure and you need to be able to close the port rapidly. Deepwater Horizon and Piper Alpha were both BOP fails. These $40,000,000 devices sit on the wellhead, have huge shear rams that cut the drill string (a huge drive shaft turning the drill bit several miles down, pumping mud through it and recovering cuttings). Once theyve cut the drill string it selas the well.
This is what a blowout preventer looks like, around 200 tonnes and it has to be docked onto the wellhead. The thread type part at the top of the wellhead is what the BOP clamps on to.
The white dangly things are weighted bottles around the periphery of the BOP socket. The BOP is lowered from the surface and has to be in perfect alignment when lowered onto the wellhead. The problem is the BOP is lowered from the floating platform above, its hanging from a 200 metre long drill string, it is affected by the heave of the platform and from subsea currents so it can swing around. As you can see the tolerances are pretty tight and we have to visually look around at 90 deg quadrants, move the rig above to get the BOP in the right place. Only when we say NOW on the comms do they drop the BOP. If we get it wrong it can write off the wellhead and cause extensive damage to the BOP. The weighted bottle we use to align the BOP 2 metres or so above the wellhead, it gives a visual indication how near we are. This is the highest pressure part of the job, everybody watching, easy to destroy the well that has taken 4 months to drill and the rig alone cost $1,000,000 per day. The drillers want the BOP installed so they can crack on everybody is pushing really hard to get it landed out and youre the one on the sticks of the ROV holding the job up.
It gets to the point where you dont have to think about it, like driving a car or van, you need to think about finding the biting point of the clutch or changing gear, you just do it, ROV piloting is the same.
Give it a go if you fancy it, electrical background is favoured for pilots (you have to maintain and repair the ROV). Rates of pay are good.
