Oddball specifications
Evans Electric
TEF LINUX ADMIN™
Sep 15, 2008
23,507
527
Birmingham
Anyone done a job where you have to follow the client's specification with their own ways of doing things, Local council, hospital estates dept etc.
Heres some we thought of yesterday.
Local council ; Earth jumper wire from accessory box to metal sheathing.
All fixings to be black japanned round head screws and wooden rawlplugs.
Police work ; Specified Wandsworth sockets and light switches . Cost a fortune, old fashioned, hard to obtain, big heavy, thick cast iron boxes with 20mmthread tapped in them. Probably last forever.
The folders for the as-fixed info must have gold embossed lettering, also cost a fortune.
Hospital job: On steel conduit had to use flange couplers onto boxes. Coupler had a flanged end & came with a thick lead washer, a shakeproof washer and extra long heavy gauge bush.
An office block ; All metal window frames to be supplementry bonded .
Finally, a spark had a photo of this one. You know those door stops that are screwed to the floor, a solid rubber block inside a half-cup of aluminium. There was an earth wire coming out of the floor and crimp lugged to the cup. !!! :^O
did you point out that by earthing the windows, and the screw, you were potentially introducing a potential that previously didnt exist
It's a made one. (Or 5, I should say).
As for the Police one - I think that is an absolute waste of money - They are closing them down, Left, Right and center.
:_|
It was a long time ago, they would'nt take any notice of us anyway, at that time. The practice stopped when someone highlighted the danger to a window cleaner who would be outside the zone on his ally ladder and a potential was present on the frame. :eek:
Did you then get sent round to snip the 'earth' to each window?!
I done that, earthing window frames, f'in mad it was, drilling a 6mm hole in a perfectly good window just so we could bond a 4mm earth to the nearest radiator!!!!!!!!!
looked very nice it did! :D :D :D :D
