Andy's context was clearly leg pulling!Cool it Andy, There is no need of that!
How can you say it was "Clearly" leg pulling? And how can you assume that mine wasn't? :|Andy's context was clearly leg pulling!Are you ok tonight, Admin?
ROTFWLHow can you say it was "Clearly" leg pulling? And how can you assume that mine wasn't? :|
Yet again a solution to a problem that shouldn;t exist in the first place. Cables shouldn;t be thrown across suspended ceilings, and if they are earthing the grid isn;t fixing the problem.The book referred to also recommends that all cables above suspended ceilings are strung from cateneary wires, with short lengths of cable direct to light fittings, ergo grid is not extraneous. However most lazy? (time poor) electricians throw cable across grid therefore grid is extraneous cos it holds cables. My only concern is howmany bonds you need to get a good bond to entire grid. 1 in total, 1 at each light point, 1 at each line?? On the one occasion I've been involved with a new grid install, I used trunking / conduit to provide extra insulation between grid and cable, and used flex cos the insulation is thicker than FTE just in case it snagged a sharp edge.
You're going to have to explain this one.cables shouldnt be overloaded, so protecting a 1.5T&E with a 6a MCB isnt fixing the problem either.
er...cables shouldnt be overloaded, so protecting a 1.5T&E with a 6a MCB isnt fixing the problem either.
just because a problem SHOULDNT exist, doesnt mean you dont have to design for it.cables shouldnt be overloaded, so protecting a 1.5T&E with a 6a MCB isnt fixing the problem either.
Point missed completely. I never said there should be no risk on anything at any point.just because a problem SHOULDNT exist, doesnt mean you dont have to design for it.NO short circuit is ever intended to exist, its all about minimising the risk should it occur.
should be done in the first place,Point missed completely. I never said there should be no risk on anything at any point. Cables shouldn't be on the ceiling in the first place, earthing the ceiling because of this isn't fixing the error.
The overload protection should be on the cable in the first place, so erm, that's it really, nothing to fix here.
Why? I thought post #1 confirmed it didn't need doing in the first place?should be done in the first place,
Fair enough, I was in agreement with that post anyway before it was posted. Under what rules\regs\circumstances would you say the ceiling should be bonded?dont think it did,you need to re-read post one,
and then you need to decide if the company that produces said publication makes the rules or NOT,
EAWR reg 16Fair enough, I was in agreement with that post anyway before it was posted. Under what rules\regs\circumstances would you say the ceiling should be bonded?
When you as the installer decide there is sufficient reason to suspect that under fault conditions the grid could become live.Fair enough, I was in agreement with that post anyway before it was posted. Under what rules\regs\circumstances would you say the ceiling should be bonded?
I don't follow? Not sure how this applies. If the grid is just sitting there, in a room, minding it's own business you'd bond it?EAWR reg 16the LAW
excellent post,When you as the installer decide there is sufficient reason to suspect that under fault conditions the grid could become live.All grid lighting is earthed through the cpc of the various circuits, there are even little earthing tags on some to connect to the grid.
There is a major key phrase given in the first post, which all posters since have chosen to ignore, and that is "under normal conditions".
What any installer would have to assess is any conditions that are not normal, or out of their control.
A grid can become live, thats a fact, under normal use it should not, as all fittings are mettalic and connected to the cpc of the relative circuits.
What I dont like about this thread is that a debate has been conducted where some views are just personal choice and not based on any facts that would help anyone decide when and if to bond a grid.
Personally I would never run cables on suspended ceilings, personally I would not bond the grid, unless I found a possible reason to do so.
If anyone is thinking what reason could I have.
Lets take the metal that forms the building, its foundations going to earth, and as such are bonded at the met.
The suspended ceiling is then hung from this metal structure, with wire, to supplement the wire and to prove continuity of earth I would bond the grid, by local circuit, or back to met.
then obviously you are either immune/or dont complyI don't follow? Not sure how this applies. If the grid is just sitting there, in a room, minding it's own business you'd bond it?
