Hi all,
I have a Solis 5kw Hybrid Inverter, Pure Energy 5kw Battery.
While I'm on the last couple of months of cheap overnight energy from Octopus my installer set me up to charge the battery overnight between 12.30 and 04.30 am.
This has been working well and i can see from the stats it's been doing that. However I have two queries.
1) The time in which the overnight charging changed on 20th April? I can't understand why. It now starts an hour earlier. I know we are in BST but that started in March. I am able to control the inverter from the PC or mobile app and can see the time setting is set to UTC ( 00:00 ) For some reason it's now charging the battery on the cheap rate as requested an hour earlier!! ( see Image 2 )To temporarily compensate this I have set charging to start at 01:35 ( see image 1 )
2) The attached ( Image 3 ) shows the battery was being charged from the grid. However at around 02:00am my households demand took all the energy it needed from the grid and not from the fully charged battery. Is this because the battery was still in the period of overnight charge ( 00:35 to 04: 25 ) and therefore could be used to provide household demand until after the 04:25am time?
Thank you
Lee
Thank you
Lee
