Partial rewire of a house regarding the redundant cables
Lexicon
Aug 23, 2021
5
If I engage an qualified electrian to carry out a partial rewire is it encumbered upon the operator to remove all the old cables or can the more inaccessable ones remain as they will be disconnected and therefore inert.
Fine to leave them in if they're redundant but usually removed both for space for new cables through joists etc and for a weigh in down the scrapyard.
Thank you
It would be more convenient if they were left in in some places where the cable run is different, less  disruption.
If you want it all removed you need to specify this before they start
Personally I remove as much as i can as I go along  .... especially if it means i can reuse drilled holes ......
