is that th e highest range yours goes to as mine says 999.999999999999999 etc when its got no resitance across the leads,
There you go ....Panic OVER!! Guinness :coatStripped the cable tonight at the house end, meggered between all 3 cores and the armour and all seems fine >500Megohms on all conductors![]()
Sorry Badger, wasnt trying to mislead you, but i fluked it up! They go to 500Meg ohmsis that th e highest range yours goes to as mine says 999.999999999999999 etc when its got no resitance across the leads,
Daddy wheres my dolly'sgoneHa ha ha, well sort of threatened my daughter the other day if she didnt behave then her dolls were going to be buried in the trench. But I didnt mean it, Really :x :innocent
should still make sure the sheath is still undamaged. otherwise water will get in and corrode armour and also get to conductors and give low IRStripped the cable tonight at the house end, meggered between all 3 cores and the armour and all seems fine >500Megohms on all conductors![]()
As i remember ...Robin stated that the cable end that got run over was unconnected (coiled). If that's the case, then an appropriately sized cable sheath heat shrinkable adhesive tube would be a far better option than amalgamating tape.if the outer sheath is damaged used self amalgamating tape wrapped like a plaster round it :^O as that will make the cable water proof again.
