Robojin
- Jan 22, 2009
- 1,122
- 0
Been asked to quote to install two external coach lights, however this will involve a cable run across pebledash to one fitting, as they only want one switch point for both
So any suggestions on fixing cables to pebledash?, a suggestion was to use a hot glue gun, valid for coax, but this sounds wrong for 230v cable runs
Even though part of the run can be under a bay window sofit, I can't avoid pebbledash and don't wish to damage render
Also limited as the customer does not want to redecorate or have trunking so rules out a route inside, best option is to feed from the garage
Suggestions welcome, please be gentle Lurch Blushing
And just as an afterthought would the cable need extra protection because pebledash are stone chips?
