The $64,000 question is. Do you ever use it?
My multifunction tester has a phase rotation function
I thought that they all did
My MFT has phase rotation and I also have a separate phase rotation meter.The $64,000 question is. Do you ever use it?
Very interesting thanks ...something I knew nothing about except that the links exist.That's a really good "Wiki" link. Loads of info. Thank you.
https://en.wikipedia.org/wiki/HVDC_Cross-Channel
They come down in price a bit!these you mean, I have one and they are not too bad for the money.
https://cpc.farnell.com/duratool/d03121/phase-rotation-tester/dp/IN07441?st=phase rotation tester
might have to get one now
The image I can see has three Croc clips on it.....strangely Red Black and Green, but Croc clips nonethelesslooks ****e. need to hold all 3 probes and then press test
i was thinking more down the lines of......could be handy to clip to a motor ( before connecting) to check rotationyou dont usually have anywhere to attach the croc clips. mine (martindale) came with 1x croc clip & 2x probes (no idea why), that soon got changed to 3x probes
Yeah it has been done!Even though you've proved rotation, I'd still always try an run the actual motor to be connected without a load attached. Someone could've messed up at the factory or rewind shop. It does happen.
