Pifco Christmas Lights
overend
Aug 23, 2022
4
Swansea
Hi
Sorry to bother with simple question. I have a set of Pifco lights, wired in series. They are not working, but I gave tested each of the bulbs, all working. I have a simple circuit tester, light up, this shows no current through the lights, but a current on the return wire without bulbs.
I have swopped fuse but still the same result.
Throw away, or is there a possible fix?
Many thanks
It is probably a broken wire on one of the lamp holders, assuming you do find it (You should take each one apart, which is never easy) you then will need a soldering iron and solder to fix it. Sorry to say, but it is quicker, easier and cheaper to bin them and buy a new multifunction set of LED lights
I don't understand what you are saying about your test results, but my way of fault finding the old series mains lamp sets was to use a Voltstick type non-contact tester.
These solved a long term annual problem, but became available just as that type of light set became obsolete!
Many thanks will try this
If you do think its a broken connection in a lampholder, then rather than take them all apart you should be able to locate it down to two holders with a simple continuity test.
