Thanks I-patch
Thanks KME. I'm glad you [and others] appreciate my position. I'm hoping a spark I know will do this PIR on the coffee shop and let me assist. I'm sure this will help a great deal. . Whilst we're on the subject - I've managed to persuade my neighbours to upgrade their CU. Do I need to do a PIR first?Nat: its a catch 22 thing. You`ll never have the confidence if you don`t do it, but you need the confidence, and competence, to carry out safely. I`d look for a repeat PIR, wherew previous records ARE available (rare as rocking horse poo), and use the previous readings as a base.
depends... it can be useful to highlight any faults, but normally i just change CU then test. stick a note in quote saying that any faults discovered will be chargeable and circuit may not be connected unless faults rectified firstDo I need to do a PIR first?
There is no specific requirement or guidance saying that you should do a PIR before replacing a CU.Thanks KME. I'm glad you [and others] appreciate my position. I'm hoping a spark I know will do this PIR on the coffee shop and let me assist. I'm sure this will help a great deal. . Whilst we're on the subject - I've managed to persuade my neighbours to upgrade their CU. Do I need to do a PIR first?
Stoopid as it may seem allow a bit more time if its a stand on a step ladder job rather than a sit on the floor job!Right! I guess my next issue is trying to price up the job
Concurif bonding needs upgraded.... it needs upgradedIf they dont want damage inside, might be possible to take cable along external wall then inside next to stop tap
Thanks Ian - very useful.Give customer a copy of thishttp://www.esc.org.uk/pdfs/safety-in-the-home/Earthing-bonding-ESC.pdf
This one is also usefull (guide 1)
http://esc.org.uk/business-and-community/electrical-industry/best-practice-guides.html
