100A TP switch fuse, been wired the wrong way, feed from meter goes through fuse, then to switch, then to SWA. so if you switch off, the fuseholder is still live.
Code 2?
also
SWA leaves switch fuse and goes to DB approx 15m away. there is no banjo's on the SWA going to earth bar, just glanded directly to metal case. havent taken a Zdb yet, but some Zs's are well within limits. codeable?
Code 2?
also
