Hi Guys I no this is appears to come up over and over again as I can see from looking through past threads,
I'm going to go for my scam assessment this year, and have a little project I can do at home to apply. Now then let's start.
At home we have pme system and an extension with a 16mm 3 core submain feeding a small 5 way c/u in it already. Off this I have placed a 10mm xlpe 3 core going up the garden which is off a 32A rcbo, the 5 way board is actually all rcbo. The xlpe swa only goes about 20m run from this C/U
The 10mm 3 core xlpe swa at present is switched off and terminated safe in a rotary isolator, And has been for 12 month's just sat there on an old shed unused. The shed is gonna be knocked down but the cable will have to stay because I'm not digging it up or extending it from where it is now.
So was thinking of placing a waterproof non metallic enclosure in the garden against our neighbours fence on my side, fixing the isolator to the side of it, then come from that with only phase & neutral only to a front end timed delayed rcd unit inside the enclosure then into a new amendment 3 type garage C/U as we're still classed as domestic, the bristish general ones are a nice little job alloy powder coated sealed for £30.00 with 63A main rcd switch 30Ma and a choice of 3 spare ways to play with.
The supply will eventually feed a new shed at the top of the garden only a light and one socket via swa run from the new setup possible another 20m run, Then bbq area lights and some sockets another swa run of about 8m this will be in after the scam assessment though just wanna get the critical bit right first ready.
OK my issue, I have fluke 1654 but no spike kit. Do I just put 3 rods in equally spaced patio area by bbq area, middle garden by enclosure, top of garden join them up together take back to C/U met, juice it up carry out ze "Ra"and if well well below 200 ohms were good, obvious if there are any metalwork these will be bonded back to the new met setup.
Like i say wanna do this for scam assessment so gotta be top notch plus safe as got my family to think off running around the garden plus neighbours etc. Be my first TT install. And a good learning curve with my new flookie wookie
Cheers guys
Cheers guys
