matt.leung
Been installing new downlights in a bathroom refurb..... went to test them (Zs) and discovered wrong polarity with voltage between N and E....
Went to the main JB and tested the main incoming feed in supply, all fine nothing wrong,
reconnected the switch line - standard T&E one way circuit, and the first spot light, and found that I then get voltage between E and N.... why would the switch line cause this.... all IR testing was fine....
headbang headbang headbang headbang
