jack2017
Hi
I'm planning on installing a small pond pump and local electricians seem reluctant to get involved
so I've decided to do the work myself.
My electrical experience is C&G from 35 years ago and my only outdoor experience is 440V 3 phase
The last 30 years have been electronics oriented so while I'm familiar with the issues I'm not
familiar with practice.
Reading the regs I found on .gov it seems I'm allowed to do this work and I've looked around and this
is what I have planned - perhaps someone could throw up red flags if there are any please?
I'm using a small oase under water pump for the pond and will power this by:
Taking a spur from a socket in the back room through the wall and onto a Diall switched fused RCD
connection unit mounted on the outside wall. The house is RCD protected but I felt this may prove
more secure?
From the connection unit run armoured 1.5mm 3 core 10cm underground with a layer of rocks on top and
run a strip of marking tape over that (under the lawn). The run is about 12 meters long.
The cable to be surfaced alongside the pool and a standard outdoor switched socket mounted on a wooden
block.
I do have questions though as I'm unfamiliar with armoured cable:
1. Is there any requirement to use ducting along the run?
2. Must the armour be flanged and grounded or can I just use it for physical protection as is.
If anyone can see any other issues I would welcome the feedback.
jack
more secure?
block.
jack
