tarted the pond revamp today heres the first stage of getting the levels again as the first time we did the pond liner we didnt do the levels correctly :z :_| :_| :_|
Its alright he gets the minimum wage.The gnome looks as tho hes holding the lining for you. :^O :^O
What do you mean he is ??
:^O
Its covering the cement patch, PatchGnome Labour? You're not using that old tarp as the liner?You are planning on putting something under the liner?
I like ponds
good man. So long as the gnome gets a day off in leu for working a b/h w/e!yes i used the carpet from my bedroom as a base for the liner on the bottom, mind you i only have floorboards in there now but weve had to build the sides up a bit and also make a better foundation on the edges of the lengths because the sdies were not very stable so have cemeneted them to build and strengthen them but im covering all the cement with a nother off cut of carpet then putting a brand new liner in that is butyl Applaud SmileyB-)B-)B-)
i hope they have appropriate BS 7654 cutouts in those lights!notice the lampposts also expertly drilled to the slabs, they are the priginals though havent been touched since last year when they were installed theres no neeed to move or mess with them....
He's got the weekend off work to help Badge out.good man. So long as the gnome gets a day off in leu for working a b/h w/e!
McDonalds laid him off because of the credit crunch - they said 'some small staff cuts would be needed'................He's got the weekend off work to help Badge out.He works in McDonalds you know.
Apparently he makes the burgers look bigger :^O
:coat
yeah they are only decorative as well as functional around the pool edgeThose pringle lamp posts would not last long in my garden the puppy would eat them.
:_| :_|And i thought mine was bad Patch.McDonalds laid him off because of the credit crunch - they said 'some small staff cuts would be needed'................(small staff - gnome )
:coat
i was about to say you definatly need your coat, but you redeemed yourself in your second part!At least the "Gnome" rating of the supply cables shouldn't be too HIGH!!! :coatbut to be honest...
I was more impressed with the meticulous attention to detail using a spirit level to position & level the gravel next to the pond!?
