same thing happened to me at my sister-in-laws house, sinking a box in and pushed the brick through a newly plastered living room wallX(As Stevie H says, check those back boxes first. Had a nightmare one once, had to chop a deeper box in, 4" wall, the brick pushed through to other room, new wallpaper, had to be done again. No way of fixing box, ended up well out of pocket. BlushingX( :_|
I had to put in 35mm boxes as she wanted the flush mount sockets and switchesX(Just fit the ones with a deep fronts the ones sf sell fit narrow boxes and bdc sold some made by doyle and tratt that also fit. Bg do one with a conversion plate for narrow boxes. I don't like dimmer switches because you get call backs like pull switches but I suppose they keep us electricians busy.Batty
I don't like this flat plate stuff. I always use 35 mm boxes on rewires but it is still tight with the flat plate stuff and you have to get boxes dead level. You have to just point the risks out to the customer about chopping deeper boxes in.I had to put in 35mm boxes as she wanted the flush mount sockets and switchesX(
what makes it worse is her boyfriend is a know it all. he has had quite a lot of the walls replastered and is getting most upset at me damaging the plaster as i dig the old boxes out.I don't like this flat plate stuff. I always use 35 mm boxes on rewires but it is still tight with the flat plate stuff and you have to get boxes dead level. You have to just point the risks out to the customer about chopping deeper boxes in.Batty
As they say lifes a *****what makes it worse is her boyfriend is a know it all. he has had quite a lot of the walls replastered and is getting most upset at me damaging the plaster as i dig the old boxes out.
When asked about payment i said 'just give me a drink' and she handed me 2,
