We recently had an engineer out from British Gas to do a survey to see if we could have an electric car charge point installed. He says he wont pass the job because we don't have protective earth bonding to the water supply. I phoned the builders of our home, and they contacted DW Hargreaves who informed them because they do it in plastic piping it doesnt need the protective earth bonding. After phoning back the british gas engineer, he insisted, because there is both copper and plastic under our sink, we must have protective earth bonding or else he will not sign off our job. I phoned the builders back, who also insist there own point that they do not need protective earth bonding as the copper pipes under the sink change to plastic as they go throughout the house.
I am banging my head against a brick wall here!! And it's giving me a serious headache! Who is right? The house was built in 2008. Should we have protective earth bonding or not? And if we call out an independant electrician is this the type of job we could get a free quote for and would he be bale to say definitively?
Thank-you anyone, for any help!
Thankyou for getting back to me!
How would I find out the earthing arrangement to let you know (sorry, complete utility novice)
BG are going to install it for free, to get it and have it put in by someone else would cost us near to £1000!! I would happily have had it done with someone else otherwise.
What do you think it would cost to get the bonding put in if we did actually need it?
From the facts you have give so far I would be inclined to agree with the builders and their electrician..
And suggest that the B.G. man is talking out of his rear end!
Reasons as follows..
Property built in 2008 is most likely a TNCS earth arrangment...
BUT even more importantly it will almost certainly have plastic incoming gas and water pipes...
Also...
the property should have an electrical installation certificate (about 3x A4 sheets)..
and a Building regulations Part-P compliance certificate.. (1x A4 sheet)
this will have been issued by the builders electrician and it will be signed to say that all the wiring..
AND BONDING is all up to current standards of BS7671 (wiring regs).
There has been no significant change in the wiring regulations since 2008 requiring any additional main or supplementary bonding to be installed.
Therefore as the builder is saying the bonding will be all as per BS7671:2008. and should be perfectly adequate for the safety of the installtion..
There is an electrical guide book to the wiring regs called the On Site guide...
http://www.amazon.co.uk/-Site-Guide-Regulations-incorporating-Amendment/dp/1849192871/ref=sr_1_1?s=books&ie=UTF8&qid=1360326307&sr=1-1
Chapter 4 talks about earthing and bonding, bullet points 4.5, 4.6, 4.7, 4.8 on pages 41-43 of that guide give the recommendation as to how and where bonding is required.
If your installation does not meet these requirements then the builders should be bringing it up to standards at no charge as it should have been done already....
But as said previously...
It most likely is.. and its the B.G. man with his head in knots!!
(it has been known before for some B.G. staff to request or insist upon things that are outside of the normal requirements of BS7671!!)
Metal work that needs bonding is basically in two main categories..
Exposed conductive parts: Conductive metal that is part of an electrical fitting, e.g. cooker, washing machine etc..
Extraneous conductive parts: Other bits of metal that are accessible within the property and are also making a contact with earth, (the ground), e.g. incoming metal water / gas pipes..
If your property has plastic gas & water pipes these are neither exposed or extraneous parts.
If the metal bits under the sink make no electrical path to earth then they are neither exposed or extraneous parts
There is NO specific requirement in BS7671 to bond a metal domestic kitchen sink, just because it is metal!
As a side note: BG will not be installing this for free.. (you or someone else is paying for it along the system with either higher fuel bills, high call out premiums or "service contracts" that give them a very handsome profit)
Options:-
Get an independant electrician to come round and check you earthing and bonding for you..
You could use the forums Find and electrician bit:
http://www.talk.electricianforum.co.uk/topic/2194-find-your-local-electrician-here-list-of-uk-qualified-electricians/
Or there are also two electrical registers that can help householders find approved electricians
http://www.electricsaferegister.co.uk/
and
http://www.electricalsafetyregister.com/index.html
Personally if I were local, for no more than £25 tops, I would check all your earthing & bonding, and verify it is up to current standards.
There is an old saying...
Jack of all trades.. Master of none...
sometimes this is true of these big organizations trying to do everything...
Tescos selling glasses and home insurance and kitchens etc.. etc..
Gas board... doing electrical work....
AA... doing home electrics...
they are all trying to cut corners somewhere..
OR..
generate more work than is necessary as staff can often be on commission and/or bonus targets!
My money would be on the Builder & his electrician been right as it is a relatively new property.
Guinness
opcorn
