Revved Up Sparky
I was fault finding last Friday at a house with a fully pumped hot water system. A brand new pump had been fitted but it would'nt work.
When I put my voltmeter across the L & N feeding the pump I recorded a voltage of 174V AC. L-E was 240V. However when I disconnected the L from the pump the voltage between L-N went back up to a healthy 240V AC.
Any ideas on what could be causing this volt drop ?. I was only there for a few minutes and did'nt check to see if the motor would turn manually. Would a jammed motor produce such a volt drop ?.
I will be going back to this job in the next day or two so I would really appreciate any advice/ pointers.
Thanks in advance.
Thanks in advance.
