question
NWDS
Jun 18, 2008
165
morning all, just a quick question
This is how its wrote,
A single phase load @ 400v ( 3ph ) AC is rated @ 6.4kW and has a power factor of 0.8, calculate the design current.
Answer is 11.5 amp
So
1000/(1.732*400*0.8)= 11.5 amp
1.732*400 = 692.8
692.8*0.8 = 554.24
1000/554.24 = 1.804
Were am I going wrong ????.
Thanks in advance
I think I have it,
6.4kW = 6400
so 6400/554.24 = 11.5
The answer/formula written stated 1000/554.24.
just goes to show that some things can be written wrong.
NWDS
Although you've got to the right answer, I think you've applied the calculations wrong!!
In the first post you've applied the pf to the voltage.
Take 6.4KW as the true power
true power / pf = apparent power
6400W / 0.8 = 8000W
Voltage bit correct
400v x 1.732 = 692.8v
apparent power / voltage = current
8000W / 692.8v = 11.5A
I think that makes sense!!
hi
i am sure that does not sound right to me.
if i am reading the op's question correctly it is a single phase load of 6.4 kW at a pf of 0.8....
that would be then an apparent power of 6400/0.8 which would give a figure of 8000VA or 8kVA.
if this is a single phase load then the VA would have to be divided by the voltage of 230V (400/1.732) so.... 8000/230 would give a design current of 34.78A
someone put me out of my miseryBlushing
I agree with your logic and think its a poorly worded question.
As the answer was given as 11.5A I simply worked it get the required answer!! :D
hji msb
if the question in the book was correct you could wire a 6.4kW 8kVA cooker/load in 1mm twin and earth.....we would make fortunes:D
Morning all, I wrote the question word for word as it had been presented, thw site it was on was swindon-massive.
NWDS
it is possible to wire a 400V load as a "single phase" by connecting across two lines. In this case the design current would be 8000/400 which would give 20A so i cannot figure out where the answer came from:_|
right! ive got it now!
6.4kW or namely 8kVA connected on a three phase load.
It is easier to picture as 3 equal loads on single phases so.....
8000/3 = 2666VA/ phase or line so the design current per line would be.....
2666/230=11.59A
Thanks Doc.Applaud SmileyApplaud SmileyApplaud SmileyApplaud SmileyApplaud SmileyApplaud Smiley
NWDS
