Hi Working on a site that was supplied with a tt system, near end of job keeping the tt set for landlord supply.
i put in 3 raidials out side lighting (low watt led).
all back to a 6 amp 30ma rcbo type b
also have 32amp 30ma rcbo type b( that's fine)
Now the 6 amp rcbo will not test trip when on, but will when the lighting legs are disconnected
also will stay on but only after 2/3 try's.
each lighting leg has tested fine
Put each one on separate still no test trip ?
have or tested the rod yet (Ze)
but will tomo.
just anyone got any ideas if not the rod ?
and yes checked installation is correct
but will tomo.
