Evening all, help required the RCD is tripping on the ring main on a kitchen circuit, I have disconnected the connections in the sockets and reset the RCD which then stays on.
If I remake the connections in the first socket only, everything is ok until I connect the cpc cables together and then the RCD trips.
Thanks in advance.
Thanks in advance.
