I had a chance of 4x 2.5mm t+e and 3 x 1.5mm t+e red and black(100m) not so long ago, didn't bother as my van was full to the brim, anyway it turns out the lad who was selling it got +
Why? What is wrong with red and black cable? Is it unsafe, can your friend not work out which one is phase and which one is neutral? I'd tell him to * cos he sounds like some nosey old git who sticks his oar in at every opportunity regardless of whether he has a clue.it turns out a friend has bought another apartment in the block and is steaming mad
What about new installations using old colours?I have just installed a simple spur off a ring main in a new residential building, only finished last year. Wiring on this ring is red/black. Installer is NICEIC member. Is this legal? Could the contractor be prosecuted if anyone "blew the gaff" on them?
I'm saying nothing, but it turns out a friend has bought another apartment in the block and is steaming mad that his
you can legally wire in old colours... just make a note of it as deviation. its probably safer than new colours, and it was never 'dangerous' all the time it was usedPart P
"Reasonable provision shall be made in the design and installation of electrical installations in order to protect persons operating, maintaining or altering the installations from fire or injury."Part P
There is no law which says that.All new work needs to comply with BS 7671
If you mean to make it appear that the work was done pre-Part P, then the colors alone don't make much difference, since the new cable was available before 2005.Why would some want to use Old colours other then to hide the age of there NEW work?
And if it's a new addition to an existing installation and you have enough old stocks, it seems rather more sensible to maintain the existing scheme than to introduce another one just because that's the new standard.because they have loads of old cable..............
Yes, Part P is a legal requirement, but all that Part P of the Building Regulations says is that:Part P IS a legal requirement
It does not mandate compliance with BS7671. The only direct reference to BS7671 in the actual legislation is for the definition of special location.Reasonable provision shall be made in the design and installation of electrical installations in order to protect persons operating, maintaining or altering the installations from fire or injury.
That's from the Approved Document for Part P, which is just officially sanctioned guidelines.Part P page 7 SECTION 0.1 STATES" In the Secretary of State's view the requirements will be met be adherence to..... BS7671"
That's not the same as saying BS7671 in its entirety. Section 0.2 then goes to say that a way (note "a" way, not the only way) of complying would be to follow BS7671. But the same section also explicitly refers to other standards which are to be considered as acceptable.In the Secretary of State's view the requirements will be met be adherence to the 'Fundamental Principles' for achieving safety given in BS7671:2001 Chapter 13.
(And that's their emphasis on the last sentence, not mine.)Approved Documents are intended to provide guidance for some of the more common building situations. However, there may well be alternative ways of achieving compliance with the requirements. Thus there is no obligation to adopt any particular solution contained in an Approved Document if you prefer to meet the relevant requirement in some other way.
But it is only BS7671 which says it must comply. And even a BS7671 electrical installation certificate has space to enter deviations from BS7671!Also when you fill out the Schedule of inspections "Identification" box (d)"Identification of conductors" this must comply with BS7671 (2008)
I think you're taking it a little far. Just wind it in a bit and have a look at what is being discussed, the use of cable that is a different colour to the current standards, the same colour that is in 99% of installations in the UK.Tell you what lets chuck the BRB in the bin and all do our own thing!
