resistors in parallel
NWDS
Jun 18, 2008
165
Afternoon fellas 7 ladies, Iam struggling with the above, I have the elec calcs ( vol 1 7th ed ) and I cannt seem to get the figures for the answers I get very near but not an exact match, any help would be appreciated.
regards Iain
Give an example of what you are struggling with OP. :)
Afternoon fellas 7 ladies, Iam struggling with the above, I have the elec calcs ( vol 1 7th ed ) and I cannt seem to get the figures for the answers I get very near but not an exact match, any help would be appreciated.regards Iain
can you work out
1 at 4 ohms
1 at 6 ohms
1 at 9 ohms
connected in parallel what is the equivelant resistance ?? make the answers correct to 3 significant figs.
RT = 1/4Ω + 1/6Ω + 1/9Ω = 1/RTΩ
RT = 0.25Ω + 0.166Ω + 0.111Ω = 1/1.021Ω = 0.979Ω
Is that what you are looking for?
no the book says 1.89 ohms
I got
1 at 0.25
1 at 0.16
1 at 0.11
added up = 0.52
1 divided by 0.52 = 1.92 ohms
Some of the answers in the book I get and some I donnt, I use the same formula all the time this is what is throwing me !!!!!!!!!!!.
thanks Iain
The clue is in the "Significant figs"
So it will be:
0.25Ω + 0.17Ω + 0.11Ω = 0.53Ω = 1/0.53 = 1.886 1.88679245283019
Rounded is 1.89Ω
0.25+0.166+0.111 = 0.527
1 divided by 0.527 is 1.89
I think that is how it should be ( I was only using 0.16 & 0.11 )
regards Iain
Thanks fellas, that is the benefit of this site.
regards Iain
can you work out 1 at 4 ohms
1 at 6 ohms
1 at 9 ohms
The other way you can check Parallel resistors is use the "Product" over "Sum" method.
e.g.
two resistors R1 & R2 in parallel.
res = (R1 x R2)/(R1 + R2).
with 3 resistors you can calc two of them first then Calc third afterwards..
i.e.
4 & 6 in parallel is (4x6)/(4+6) = 24/10 = 2.4
now do
2.4 & 9 in parallel is (2.4x9)/(2.4+9) = 21.6/11.4 = 1.89473 etc.. =1.89
which proves you have your calc correct using the other 1/R1 + 1/R2 + 1/R3 = 1/Rx method.
