Home made Low resistance
Front;
http://i291.photobucket.com/albums/ll306/SPECIALLOCATION/HMLOWRES.jpg
Back;
http://i291.photobucket.com/albums/ll306/SPECIALLOCATION/HMLOWRESBACK.jpg
This item was produced a fair while back for the purpose of checking my cheepo maplin multi-meter,
NOT specifically in relation to Part-P or 230v electrics.
e.g. within telecoms & alarms systems.. often can be using a wider range of low resistance values than are required for mains electrics..
It was constructed from various items already knocking around in my garage & tat component boxes!
Features & Construction:
It consists of 17 resistors mounted on a bit of strip board
with some edge-connector screw terminal strip on either side of the strip board.
(the screw term edge strips were used on some equipment with my previous employer,
in 5-way & 8-way lengths. so they were acquired foc! )
The whole assembly is mounted on a bog-standard double socket blanking faceplate, with a couple of end pieces cut off
& sandwiching the strip board between the plate ends with some small nuts & bolts (see picture!)
I chose three standard resistance values then used the various multiples to provide a quick and easy selection of resistance which will encompass more than one scale on the meter.
i.e. 6 x 1Ω multiples as follows:- 0.1Ω, 1.0Ω, 10.0Ω, 100.0Ω, 1.0KΩ, 10.0KΩ
6 x 2.2Ω multiples as follows:- 0.22Ω, 2.2Ω, 22.0Ω, 220.0Ω, 2.2KΩ, 22.0KΩ
5 x 4.7Ω multiples as follows:- 0.47Ω, 4.7Ω, 47.0Ω, 470.0Ω, 4.7KΩ
1 x straight through NULL connection.
I stuck some nice little signs printed onto self adhesive labels to remind me which values were which!
The screw term strips does mean if you want to,
you can stick a bit of alarm or com
