bluetobits
- May 10, 2010
- 294
- 6
I think Phil described it well enough in post #7
And never go back to different breakers
Nothing, its a ring circuit or a radial circuit.ok so the difference between a ring main and a ring final ? im so confused right now
Bit of history for you, rings came out of a very high copper cable price
Not directly, AFAIAA the reason for the ring main was it was easy to convert a couple of 15A circuits into a ring and add a few more sockets along the way without worrying about stretching the limits of the radial circuits.
im currently doing a electrician course and im at a stage where i am going through ring and ring final circuits, i get how both of these work but i cant seen to understand why choose one over the other ? what are the situations you would use each one ? thanks in advance
thanks guys ,
my understanding is that a ring starts at CU and ends CU . radial ends at last outlet , and a ring final is from what i know its something to do with how its connected at the CU but i cant find out why. its something like it instead of going back to the same breaker they go to seperate ones so if the circuit was to break you effectively have two radial circuits - so am i confused ?
I do remember and have encountered Aluminium cables which I understand was cost saving.
Yep, before my time but that was 70's, 60's? Rings have been about longer than that.
The ring circuit and the associated BS 1363 plug and socket system were developed in Britain during 1942–1947.[1] They are commonly used in the United Kingdom and to a lesser extent in the Republic of Ireland. They are also found in the United Arab Emirates, Singapore, Hong Kong, Beijing, Indonesia and many places where the UK had a strong influence, including for example Cyprus and Uganda.
1940's according to Wiki.
Deano ... consider the old method in domestic premises , back in the 1940s - 1950s , rubber cable , sockets could have been a mixture of 2A x 2 pin .... 5A x 2 pin ...5A x 3 pin .... 15A x 3 pin or use a bayonet adaptor, remove the light bulb and plug into the ceiling rose.
The 15A sockets would all be wired back separately .
So back then , one simple ring main using 13A BS 1363 sockets would be adequate for a small house .
It saved cable .
It could be added to.
It standardised all the plug tops .
Not uncommon to find a 4 way board for a house :-
8 Lights
6 Plugs
Cooker
Imm. Htr.
You need to know that the names of things in this trade are like the staircases at Hogwarts , they keep being changed by those above us and the use of initials is encouraged until idiots like me don't know what others are talking about .
To understand types of Supply you need to speak latin and it all makes sense ..so for Earth say Terra , as in Terra Firma then a TN-C-S begins to make sense.
Spur units are now FCKU or something .
Fuseboards or "The Board" are CUs or a Consumer's unit shortened to Consumer Unit.
The obvious one of course was to change all the cable colours .
Fuses are now OPD s or something similar , so it goes on .
Conduit & trunking is now Cable Management . And so it goes on.
Now theres a new one on me !!the powers that be like to keep changing the name of things...
it used to be 'live'. then 'phase'. now its 'line', but just to complicate things even more both line & neutral are also 'live'
we also had direct & indirect contact. that was too complicated so its now basic & fault...
Up here it is BELT for a medium sized shock, TICKLE for a smaller shock, CLOUT or A REET CLOUT for a larger size shock.Can I still call shocks .."Belts" or "Pissers" or have they changed too ? :innocent
