isnt that cross section? I could be wrong.2.5crbvcurbvubruvbruvb/4 * 2 == 5crbvcurbvubruvbruvb/4
Aggr. 2.5 is the CSA (as is 5) not diameter.isnt that cross section? I could be wrong.
about the time someone noticed it was a good alternative!andy :^O when fuses were rated in inches
They most certainly are not...Aggr. 2.5 is the CSA (as is 5) not diameter. So actually r=sqrt(CSA/crbvcurbvubruvbruvb)
and surface area is 2crbvcurbvubruvbruvb*sqrt(CSA/crbvcurbvubruvbruvb)
so does 2crbvcurbvubruvbruvb*sqrt(2.5/crbvcurbvubruvbruvb) * 2 equals 2crbvcurbvubruvbruvb*sqrt(5/crbvcurbvubruvbruvb)??
2sqrt(2.5/crbvcurbvubruvbruvb) equals sqrt(5/crbvcurbvubruvbruvb) ??
5.61 equals 3.96 ??
So no they are not equal.
eh up Lostit...hmmm someone likes his scientific calculator
No too much Theoretical Physics at Uni many years ago.hmmm someone likes his scientific calculator
Love the short cuts at the top of the monitor - thought it was some weird equation to start withfame at last
i was wondering what it wasLove the short cuts at the top of the monitor - thought it was some weird equation to start with
ready to be bored :^O i'm into turbo cars heavily data logging and all that geeky stuff
my ecu records all sorts of engine parameters rpm, throttle angle, water temps etc and boost pressure. my ecu records in psi but i like to use bar so that formula converts that for me. then there is an oxygen sensor in the exhaust that makes sure its running correctly air/fuel mixture wise my ecu records this in millivolts which i need in afr. the next 4 should be usefull to all of us when using word or excel etc i.e 100msq = 100 (hold Alt press 0178) gives 100m
in most cases, 4mmSince 2004 I use only radial circuits in installation of new circuits (very often in new kitchens and other extensions).I agree with the approach that a radial circuit is safer and more practical than a ring circuit; as mentioned above, broken ring crates a condition of 2.5mm2 cable on a 32A MCB, much easier for testing, can add spurs without problem and just to add if you wish to allow bigger load on the circuit you can use 32A MCB with 4mm2 cable... yes it is easier to work with 2.5mm2 cable but 4mm2 is not impossible.
