- Feb 27, 2008
- 11,018
- 0
When I see a corgi guy I know I am going to have a word and get this cleared up. Wheres J.L I am sure he could put us right.Nice one batty. Thanks for posting back.
Batty
afaik, what the bbc has said is true. some boiler do have cover inside the main cover, others dont. problem being, like the valliant, you need to remove the cover to wire up/add room stats etcI find this hard to believe that the only seal between the boiler fumes and the room is a metal case. The boiler was a valliant and did not look that old I may be wrong but this seems to be bo***oks
Batty
How many boilers need a corgi registered person to take the front cover off only one the one on rogue traders.sorry little bit late here, as above some fronts are decorative only,but yes i agree if say your a sparky and go to wire a worscester boiler you have to remve the front cover which is also the combustion seal to you would not be able to do it .
but now manyfacturers put a fly lead to the board for this but never temp up the stat.. so you could wire it up without removing the cover.... but how do you know its correct without checking the termination. ???
also remeber the combustion chamber is totally sealed anyway and can not leak in any way on most of the new 1`s now so even if you pull offthe cover there wont be fumes leaking.
its a load of cack, just carry on as normal no one cares anyway.
How many corgi lads are part p registered not many I think they probably pay enough to corgi already with out extra cost of another course for the part p.i fit baxi and they dont. i know worscester does. i think the valiant does to .also remember to that if you wire a boiler and turn it on you are responsible for it.
the only way an electricain should wire a boiler is if the engineer is there too and they should turn it on together then the corgi lad should commision and set up the boiler for the customer while the electricain does all is tests.
but this is the real world i am afraid.
we care.its a load of cack, It that a technical term for the boiler cover??
