Data stream
Hey folks,
I am wondering if it would be possible to run a Heat Pump Dryer, 1.90kWh Rated input power 800W once ever now and then from batteries that are charged via a small wind turbine up on the roof, I'm in a great location and it's pretty windy all the time, maybe not so in the summer but then the clothes would be dried outside or on a clotheshorse, I was wondering if I got an inverter rated maybe 1000w and said batteries would this be possible.
I'd been looking at the following :
Streetwize 1000W Modified Sine Wave Inverter
MOES Smart Dual Power Controller 80A 16KW Automatic Transfer Switch for Off Grid Solar Wind System ATS DC 12/24/48V AC 110/220V
I was thinking that a 12v battery would do the following, 1200Wh÷1000W=1.2 hours
Inverter Battery Capacity (Ah) = Power Requirement (W) x Backup Hours (h) / Battery Voltage (V)
I know there's loads of posts about buying a Anemometer, but honestly it's always windy here! well mostly! but it's just to charge the batteries and I don't use the dryer very much.
Dryer Energy Requirement:
Rated input power: 800 W.
Dryer runs at 800W continuously for 1 hour.
Energy required per hour:
800 W = 0.8 kWh
Battery Specifications:
A typical 12V car battery has a capacity of around 50Ah to 100Ah (amp-hours).
Energy stored in a 12V, 50Ah battery:
Energy = 12 V × 50 Ah = 600 Wh = 0.6 kWh
Energy=12V×50Ah=600Wh=0.6kWh.
For a 12V, 100Ah battery:
Energy = 12 V x 100 Ah = 1.2 kWh
Energy=12V×100Ah=1.2kWh.
Assume inverter efficiency of 90% Energy Available from Battery:
Only 50% of the battery capacity should typically be used (to prevent deep discharge, which damages batteries)
Usable energy from a 50Ah battery: 0.6 kWh x 0.5= 0.3kWh.
Usable energy from a 100Ah battery: 1.2 kWh x 0.5 = 0.6kWh.
Energy Needed for the Dryer:
If the dryer runs for 1 hour at 800W, the energy requirement is 0.8 kWh.
Number of Batteries Needed:
For 50Ah batteries: 3 batteries.
For 100Ah batteries: 2 batteries.
This calculation is for 1 hour of dryer operation. If you need longer runtime, multiply the battery count accordingly.
800 W = 0.8 kWh
