Hi haven't made a post in a long time but this issue has got me thinking. This is the 1st time I have had the consumer unit quite a distance from the meter. Needed some advice in making sure I am making the right decision.
currently I have been working in a house that did have three cu's, two running the original part of the house and another which had powered a extension which was done over the past 10 years. The cu powering the extension is fine and does not need attention. The other two I have cut off and also removed all the wiring on the original part of the house as it was a complete joke by having jb's all over the place and taped up connector blocks and also wires that had been attacked by a mouse infestation at one stage. Due to this I have reworded the original part of the house but run all cables to the extension to the cu that is left.
i will be putting a new cu under the other to power the original house.
My my plan was to have an additional meter box outside next to the original that will contain a 100a fused switch which will have 25mm swa feeding the new and existing cu.
Does this sound about right to another electrician who has been in the same situation as I am now.
thanks
jason
thanks
jason
