- Nov 28, 2009
- 14,813
- 992
I spent the weekend moving my daughter into a rental flat in Elgin. That was 2 trips of truck and trailer loaded with furniture, assembling it all, and then connecting the washing machine.
No 1 fault, the socket for the washing machine was not fixed to the wall, instead a single socket in a surface back box just hanging by it's wires. No means to turn off the washing machine from above the worktop.
No 2 fault, the kitchen worktops have upstands which are quite thick and the wall sockets are very close, so any plug with a stiff flex outlet will not plug in fully.
No 3 fault, a socket in the hall looks to be scorched around the L pin, needs replacing.
No 4 fault, I looked at the CU, a split load Proteous box has 2 spare unused ways, instead of proper blanks, the 2 vacant slots are covered by tape. That tape is all that stops someone putting a finger in and onto the busbar.
And that is of course before doing any actual testing to see if it is otherwise safe. If anybody really gave that a satisfactory EICR they are not fit to call themselves an electrician.
What angers me, is all these are quick fixes, I would probably have fixed them quicker that it would take to write the paperwork to fail it.
I have asked daughter to request a copy of the EICR and gas safe certificate from the letting agent.......
Other issues, the boiler was not working when they got there. The error code suggested no gas so after waiting nearly 24 hours for an "engineer" to visit he pushed a few buttons on the boiler to reset the error and it started. The water pressure gauge is not reading so no way to know if the water is okay or not. Would that be a fail for the gas safe?
Also I noted the flat next door had some kind of frame around the door for something to slot into, so I wondered if that was a flood thing, and sure enough a bit of searching reveals this is a high risk river flooding area right next to the River Lossie, and it has flooded several times the most recent being I think 2007. It is now supposed to be protected by the new Elgin flood protection scheme completed in 2015. Not perhaps an issue for a rental but I would not buy it. The previous flooding history probably explains the wonky / sloping floors, and recent kitchen and bathroom, probably re fitted after the last flood.
