a knowledgable person.why would you need too???
Well I'll put my hands up & be honest.Yes I have cut seals & removed the service cutout fuses & if its a new meter that has the integral isolation switch , then I have removed the seal the meter mokeys have the habbit of fitting to the switch.
Why.....................because I dont fancy working with live tails! & most customers dont want to pay out or wait 24 days for SSE to do what I would do anyway.
Agree with you both here. As Mr. Steptoe says, what`s the problem - unless you intend to attempt to comply with EAWR`89 - Then you`ve got to prove it was :
a. unreasonable to work dead.
AND
b. reasonable to work live.
However, some tails can be a real pain to deal with, in limited space etc, and then I pull the service fuse. NEVER the meter seal though - Never seen a need to.
On a connected note - one of the scottish DNOs piloted a system whereby qualified sparks could call them on a dedicated line, give the address, and were allowed to cut seals.
NICEIC held talks with other RECs/DNOs, who pretty much said:
"It`s our stuff, and we`re not having anyone else touching it."
And on a similar point again - upgrade of EC on PME. Our DNO has started fitting the Earthing terminal INSIDE the cutout. They`re charging up to
