- Dec 2, 2009
- 350
- 0
Hello folks,
It looks like I'm getting a fire damaged section of Carpark to repair.
Problem is all of the existing ligh fittings are assembled with security screws. The screw head has 4 drilled holes in a square pattern. I don't have the hole centres at the minute.
In the past I've Managed with a "spanner bit" used for "snake eye" security screws (two drilled holes)
But these fittings are old with corrosion in place. I snapped the pins off three bits last week on a similar fitting. Probably due to poor quality bits.
Does anyone know where I can buy good quality individual spanner bits, or a 4 pin bit to suit? It's going to be a long job if I'm drilling out bolt after bolt. Expensive if a have buy a kit each time I snap a pin off.
