Depends on swa csa the quantity of cores.phew!thanks again, done something right then.
if you use the amour, what to you put on the cert for the size of the cpc?
10mm 2 core pvc/swa has armour csa of 41mm
is it a megger?Good idea, hadn't thought of that one Andy. I just tend to do R1+R2 and add to Ze since my test gear started playing up when doing Zs using 3 leads to avoid tripping RCD on lighting circuits.
Sorry got side tracked googling shutters that drop with fire/smoke detection.thanks M,is there a table for this?
We had one of those at one place I worked. It nearly decapitated/trapped a number of customers...Sorry got side tracked googling shutters that drop with fire/smoke detection.
