Page 113, Reg: 531.4 RCD's in a TT SystemReg: 531.4.1 If an installation which is part of a TT system is protected by a single RCD, this shall be placed at the ORIGIN of the installation unless the part of the installation between the origin and the device complies with the requirements for protection by the use of Class II equipment or equivalent insulation. Where there is more than one origin, this requirement applies to each origin.
Now correct me if i'm wrong but does that not just confirm what I said?
If a customer has a BS3036 board which has had the rewirable fuses replaced with MCB's as an upgrade and the whole wiring has been tested and proved safe and satisfactory but wants a shower fitted or a new circuit ie: sockets etc but cant afford a new 17th ed board. This option complies with the Regs. Where I live and work there are a LOT of TT installations.
Granted, its not the best solution as we advise but it works out the most viable and cost effective for the "cheapskate" customers.
Please someone correct me if i'm wrong and explain why?
