Siezed screws
NozSpark
Seaman stains™
May 28, 2008
12,316
122
North Wales Riviera
I have some terminal screws in a CU (earth and neutral) that are seized (possibly rusted),,,, I was wondering what the best method would be to free them
I was thinking of "painting" the thread with some WD40 or Plus Gas,,,, definitely not spraying them!
GT85 is waaaaaaay better than WD40
Personally I'd maybe try cutting the cable,    :C
Btw, painting doesn't have the same effect, the 'gas' is what carries the effect, unless you have some normal pump action WD,  which I'm guessing you don't,
Cheers..... cutting the cable isn't going to happen.... it's a SQ D QOE plastic CU IIRC and nearly all the earth and neutral terminal screws are seized..
TBH I'll get whatever I need to as a can of "whatever" has to be worth a punt,,,, otherwise it's a CU change :eek:
I would go for Plus Gas  or the very similar WD40 penetrating fluid NOT the standard WD40
also try 'tightening' the screw very slightly before spraying
be prepared for a day of tears though
BFO soldering iron is quite handy....best to use before the penetrating fluid....dont want Trumpton making another rule
How BFO do you want,,, I've used some with a 1" wide tip before.... used to have to can instruments IYKWIM ;)
could you use heat?
Heat could prove to be difficult.... it's a plastic CU!!!!
Could have been overheating which caused the threads to melt in the first place, it's a plastic CU after all.
`Cut drill re-thread?
oar
Can you get new terminals? Had some from a starbreaker skeleton that saved my butt once.
:ph34r:
...Just stabbing away wildly in the dark like OJ Simpson ( allegedly).
WD40. on the plus side, its also non-conductive
(yes, i did do an IR test on some a while back...)
Andy, you might be correct, but at a place where I once worked we were not allowed to use WD40 in electrical enclosures as it was blamed (after an incident investigation) for a flash over, granted it was a 600V 3 phase and above supplied enclosures
I can not prove either way wether it is suitable, but if used I would make sure it was only used sparingly on the exact point it was used rather than sprayed liberally.
Noz, is it possible to grip just the one screw head with water pump grips or similar and just turn it  1/4 turn  then screwdriver ?
It's a bit of an acquired art but you can also use side cutters on a seized screw head.. As already stated tighten a little first then unscrew and go a quarter turn back in for every half turn you go out if that makes sense?
That does absolutely make sense,,, I've tried most mechanical methods that I had to hand at the time,,, I was hoping that someone might know of a chemical releasing agent that would be suitable and might work....
I don't like the idea of soaking a consumer unit with WD40 or the like so thats why I was thinking of "painting" something like WD40 onto the threads.... I might try a micro torch
That basically allegedly turns rust into a solid primed surface,
Almost the opposite from what Noz wants,
If you do 'paint' WD or similar on, make sure you get proper pump stuff, not aerosol,
Try some weak acid,??????
Impact driver,?
The type you hit with a hammer,
not the cordless type we so often overuse.
Impact driver,?
Odd stuff, only used it on the van and around the home. I thought it just disolved the rust and left a black residue you clean & prime :C
I've never over used an impact driver  :innocent
@NozSparkSure you can't remove the Terminals?
