Morning all,pricing a small job, and in the spec they ask for DP switched sockets. now I generally fit single pole ( as they are cheaper ), but has anyone got ant valid explanation for DP as opposed SP, can't seem to find anything in black and white.
Macca
Guiness DrinkGuiness DrinkGuiness Drink
For what its worth.. heres my tuppence worth.....:|Blushing
Clients requested spec "DP switched sockets" is your bit in black & white..
If thats what the customer requests thats what you quote for...
DP sockets or SP Sockets or NON-Switched Sockets,
are ALL acceptable means of isolation or switching off for mechanical maintenance..
Table 53.2 pg117
537.2.2.1 pg 119
537.3.2.6 pg 120
Functional switching doesn't need to switch Neutral, 537.5.1.2 pg 121
Plug & Socket can't be used as emergency switching, 537.4.2.8 pg
Also pgs 33 - 35 OSG, isolation & switching.
In a nutshell, as long as NOT for emergency switching,
if device comprises a plug & socket it doesn't need a switch but it can have one if preferred.
Another advantage of DP is if accidentally wired socket reversed. still isolates the Live..
Disadvantage, Possibly greater risk of one pole of switch going faulty..
e.g. more moving parts.. maybe more susceptible to bad connection & overheating?? ?:|
Personally I always fit DP sockets.. there isn't a fat lot in the cost...
& the customers paying anyway!
If the customer asks for bulkhead light you don't fit a coach lantern....
no different Sp / Dp / Non Switch sockets.. IMHO?
you probably knew all them bits anyway...
but may help others reading & point em to a few reference chapters.
