Good evening everyone, I intend to DIY install a small PV system with simple grid tie inverter. Just a cheap as you can but everything done properly. I have an steel portal frame building that's 45' by 16', the roof is steel box section fixed to wooden purlins - entirely standard agricultural use. The building has a southerly facing aspect which is ideal, but unfortunately the roof has one foot of drop over its 16' width to the North. This was for simply for rain drainage and sadly it's in a bad direction for solar panel orientation. I've found some 435W monocrystaline 2180mm x 996mm x 40mm panels at a decent price. I'm guessing I need an arrangement to point them towards the south at about 30 degrees of inclination, rather like ground fixed panels? What do you think, some sort of aluminium bracketery, maybe stuff commercially available or will the first gale rip them all off? I'm not sure how mechanically strong the PV panels are.
Thanks, Julian
Thanks, Julian
